Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
michaelkenward
Nov 10, 2022Guru - Experienced User
KeenEye wrote:
It looks like the Orbi App doesn't like the new security patch on Android devices.
Not really. The same fault is there on ancient, unpatched Androids.
KeenEye
Nov 10, 2022Tutor
Oh Really? I thought I started to have this issue since my phone was updated. I've submitted a bug report from my app as a lot of others had done. I hope NetGear fixes this ASAP. As I mentioned in my post, this issue is definitely only on my Android device. The App works on Apple devices.
- michaelkenwardNov 10, 2022Guru - Experienced User
I find that Android updates can also provoke app updates.
Maybe that happened to you.
- CrimpOnNov 10, 2022Guru - Experienced User
My Android phone no longer receives Android software updates. (I remain on Android 10.) Same issue with the Orbi app ("Logon timed out.")
Android 8 and 9 here. Still getting updates as far as I can tell.
Most recent update for Nighthawk app was 12 Oct 2022, Orbi app was 5 Oct 2022.
