Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
RockRite
Nov 05, 2022Tutor
Same issue here.....noticed Orbi app "Logon timed out" error this morning. Never had issues with Orbi app until today.
Issue -
Unable to login using admin credentials via Orbi app (Android). "Logon timed out, try again later, reboot router". However, logging in locally via web browser works without issue.
Possible Fix (Below steps worked for me. NOTE - turn OFF WiFi on Phone prior to start) -
1. On phone, opened Settings\all Apps\Orbi\Storage & cache
2. Cleared storage (alternative is to uninstall and reinstall Orbi app)
3. Launched Orbi app
4. By checking this box.....I agree
5. WiFi Auto Connect.....Allow\While using the app
6. Sign into existing account (Netgear)
7. Enter credentials.....Log In
8. Add trusted device.....Trust Device
9. Continue
10. Turn on TouchID.....Maybe Later
11. Go to Dashboard
12. WiFi Not Detected.....select Connect Via Anywhere Access
Connected, closed Orbi app, opened app; works okay now!
Steps 4 - 11 not too relevant and may be different on your device. Important step is to turn off phone WiFi to force Anywhere Access to show up during install/connection.
Not sure if this will work for anyone else, but hope it helps!
RCNT_Matt
Nov 13, 2022Aspirant
Wow, appears to be working now. How in the world did you figure this out? Thanks!
