Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
BobArnett
Nov 16, 2022Tutor
Are you referring to an Orbi App update or an Orbi firmware update?
KeenEye
Nov 16, 2022Tutor
Orbi app latest version 2.21.0.2590 in the Play Store
- MichelH61Nov 16, 2022Star
Apparently, first in the USA:
https://community.netgear.com/t5/Orbi-App/Android-Orbi-App-2-21-0-2590/m-p/2272469- FURRYe38Nov 16, 2022Guru - Experienced User
If your still not getting logged in, can someone try this and let us know if this helps get you back in at all?
Same process that seems to work on NH app, may work on Orbi app. This is only a last resort check to see if you can get back in.
- Someone77Nov 16, 2022Tutor
Just got the update from the playstore ver. 2.21.0.2590. It did not fix it. Problem and error message unchanged. I cleared cache and storage before updating app.
