Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
Someone77
Nov 16, 2022Tutor
Just got the update from the playstore ver. 2.21.0.2590. It did not fix it. Problem and error message unchanged. I cleared cache and storage before updating app.
CrimpOn
Nov 16, 2022Guru - Experienced User
Someone77 wrote:
Just got the update from the play store ver. 2.21.0.2590. It did not fix it. Problem and error message unchanged. I cleared cache and storage before updating app.
The new app version works correctly on all four of my Android devices.
(Embarassed not to have considered how long it would take for Google Play to change the app version and roll it out to various geographic regions.)
Once again, the new app version required me to enter my Netgear app credentials on one tablet, but not on my older Android devices.
- jtcommunityNov 16, 2022StarConfirmed: newest version (2.21.0.2590) seems to have solved the problem. Android local login is possible again. Thank you NG.
