expectedbetter1
May 23, 2023Tutor
Can't logon to Orbi - "Logon timed out, please try again"
A previous thread indicated that this was fixed. It does not appear to be. I updated my firmware and iPhone app. Deleted and reinstalled my iPhone app three times based on the previous thread. Sa...
sajnikanth
May 11, 2025Initiate
Issue seems to be with the latest iOS version. Here's how I fixed it:
- You need an older iOS device. I used my kids' iPad running iOS 15.7
- On the older device, install Orbi app and login to your netgear account
- Without Anywhere Access, login to your router (admin / <password>)
- You should have logged in successfully
- Go to Settings -> Anywhere Access
- You should see Anywhere Access is enabled
- If so, Disable and Enable it. If not, just Enable it
- On your device running latest iOS, quit and relaunch the app
- When you see the screen to login, quickly click on Login using Anywhere Access
- You should be able to login now
Good Luck
Vitalij_R2
May 23, 2025Aspirant
Does there exists the way connect the router to Anywhere Access from the browser?
- FURRYe38May 23, 2025Guru - Experienced User
No.
