Raymonddeniet
Oct 23, 2019Guide
Connected devices not correct
Hi,
Can anyone help me out please. When I log on to my Orbi router and see the connected devices I don't get to see them all.
I can only see 15 when about 20 are connected.
What do I have to do to see them all (for catogorising and maintenance and renaming).
I hope it is possible to get an actual list on my screen.
- Retired_Member
Raymonddeniet wrote:Hi,
do the devices work? If they do, don't worry about it. Lots of complaints about the app.
- Yes, they all work fine.
Ok thank you. I thought it was me.
I hope they will get the app better in the future.
Thanks again- Retired_Member
Thanks againto help the NG team...you may want to post the FW you're using. Thanks
