wRiNkLe_sTiCk
Oct 20, 2024Apprentice
Connected Devices showing up as wrong device
Anyone know how to get connected devices to show up as what they actually are in the Orbi app? A while back I used to be able to log into the router via a browser and manually set name, brand and mode...
wRiNkLe_sTiCk
Oct 21, 2024Apprentice
CrimpOn wrote:
wRiNkLe_sTiCk wrote:
Anyone know how to get connected devices to show up as what they actually are in the Orbi app? A while back I used to be able to log into the router via a browser and manually set name, brand and modelI have had an Orbi for over seven years. I do not recall ever having the ability to create an entry for "Brand" on the web interface. I simply included the brand information as part of the model number, such as "Epson ET-3760".
You are right, now that you mention it, I recall I used to set the name and combine the brand and model together in the Device Model field via the web interface to have it display correctly in the app. But, now in the app they have the model and brand separate and the model doesn't appear to map to anything, or it is pulling from some table on the router that has old information as I previously had a Surface Laptop 3 on the network and this brand-new television is showing Surface Laptop 3 as it's model in the app. Disappointing that I spent as much money as I did for this mesh system, and they can't get something this simple correct. The least they could do is allow us to override/set it in the app. Currently the only editable item in the app is the name. I guess the silver lining is that the router performs great.
CrimpOn
Oct 21, 2024Guru - Experienced User
I have the Android 'app' version 2.41.2.4183 and find that text in the 'model' field appears after the manufacturer information in Connected Devices. I changed my printer model to "xyz", waited a few minutes, and then connected the app and there it was "Epson - xyz"
Although....... Noticing that the picture was incorrect, I edited the picture to be the printer icon again, and when the list of devices appeared..... none of the devices had the model text below each item. Went out of Device Manager, came back into Device Manager and now every device displays that text in small letters under the Device Name.
This is not shaping up to be a good day for the Orbi 'app' (see the post about Anywhere Access)
