TheBroker
Jul 21, 2021Initiate
CRAZY!!! - No Clear way to change or add "My Trusted Devices" in "Two-Factor Authentication" in App
I've searched and seen the threads but no clear way of adding a new phone (iPhone) and deleting an old phone (Android) "Primary" from "My Trusted Devices" in app. This is nuts. Should be a simple thi...
- Oct 26, 2022
I experienced the same frustration ... and was able to resolve by:
Uninstalling the Orbi app from my iPhone.
Running a manual setup.
At the end of that process, it asked whether I wanted my verification code sent to my email or phone. Always before email was the only thing that worked. This time it actually sent a verification code to my iPhone. Then it said my Orbi was already set up so I went back to the Dashboard. All works!
Note that this process included following their instructions to disconnect the Orbi from the modem and power cycle the modem, then plug your Orbi back in to the modem. Never had to touch my satellite - not even to re-sync.
Hope this helps!
DLS94
Jul 31, 2021Initiate
Hi,
I was having the same issue and was not able to add my new device. I deleted and reinstalled the Nighthawk app. While going through the steps to set up the app again it prompted me to add ("trust") my new device. The new device appeared in the options for the two-step verification. I made the new device my primary one then deleted the old device. And it finally worked after wasting several hours trying other options.
Heikkilunta
Oct 25, 2021Aspirant
The installation of Nighthawk allowed me to add a new trusted device. My Orbi routers are not supported by the Nighthawk app, but the it did work. So I was able to delete my old iPhone as a primary trusted device. Make my new phone a trusted device in the Orbi app and then delete Nighthawk.. I imagine the same would have worked if I deleted and reinstalled the Orbi app, but was concerned about what I might lose if I do that. Anyway. A clunky but effective work around. Would like to see the app fixed to accomodate changes like this.
