DannySK
Aug 06, 2022Tutor
Delete inactive devices from Orbi app
I'd like to delete devices from my Orbi app device list that are no longer relevant. Basically, I'd like to refresh the list to only currently active devices. The list has gotten long! Is that possib...
CrimpOn
Aug 07, 2022Guru - Experienced User
Could you please indicate which version of the Orbi 'app' this is?
My current Android Orbi app displays only active devices. There was a time (months and months ago) when it displayed every device that had ever connected, but it quit doing that several releases ago.
- DannySKAug 07, 2022TutoriOS 2.19.
- KevinLiTAug 08, 2022NETGEAR Moderator
Hello DannySK,
Welcome to the NETGEAR Community!!!
I understand that you would like to see all of your devices that are currently connected to your network in one list using the Orbi app. Our sort feature allows users to prioritize connected devices based on the connection status.
- To utilize this feature please navigate to the following settings on your Orbi app:
- First, Navigate to the Device Manager
- Then, Select Status ( Located in the upper right corner)
- Finally under Sort By Select Status
For instructions on how to fully remove a device from the Device manager please navigate to the link below:
Best,
Kevin
Community Team
