stevefxp
Mar 21, 2020Apprentice
Delete Trusted Device
Has anyone figured out how to delete devices from your trusted device list in the Orbi app?
- Mar 21, 2020Deleting Trusted Devices is actually very easy, it's too bad Netgear doesn't tell you how to actually do so. Open the Orbi App, login and connect to your Orbi device. Next press the Home icon located top left, then select Account Management. Now select login settings, and open My Trusted Devices. You should now see a list of your trusted devices. Press your finger on the right side of the device you want to edit, and without letting go slide your finger to the left. (Similar to Deleting an email. You will now see Edit Divice Name - Set as Primary - Remove Device.
SpinTered2n0w
Mar 21, 2020Initiate
stevefxp
Mar 22, 2020Apprentice
Thank you thank you thank you!!!
