EricPh
Mar 24, 2025Initiate
Deleting access to a CBR750
I have a CBR750 at a rental property I am selling. I want to relinquish ownership of this device, and remove my remote access to it via the ORBI app. I also have an ORBI setup at my permanent resi...
- Mar 24, 2025
Thanks for the quick response. To clarify, I should-
1, DO a factory reset on the physical device.
2. Remove the device from my my.netgear account.
3. DO NOT Delete MY Netgear Account (which chat support recommended. I thought that sounded odd)
This will allow the new owner full access to the device once he sets up an account and adds the device to his account.
Correct?
KevinLiT
Mar 24, 2025NETGEAR Moderator
Hello @EricPh,
Welcome to the NETGEAR Community!
As mentioned by @FURRYe38 please visit https://my.netgear.com to remove your CBR750 from your account. Be sure not to select the "delete my NETGEAR Account". That option will delete your account associated with NETGEAR causing you to loose purchase history, paid subscriptions, and purchase history.
Best,
Kevin
Community Team
