tamason8
Jul 29, 2022Aspirant
Desktop Keeps Joining Network as a New/duplicate Device
I have ORBI AX6000. I have my son’s desktop on a separate profile which has parental controls/limits. However, his computer will connect to the network as a new device and duplicate itself in the devi...
tamason8
Aug 01, 2022Aspirant
Firmware: v4.6.8.2.
ISP: Suddenlink (I think recently changed name to Optimum?)
Modem not provided by ISP.
Net gear CM1000
In the screenshots you can see the “Home” profile, which is the general profile devices go under when they connect to the network. The other profile is my son’s profile which is limited by the Parental Controls in the Orbi app. The computer will connect to the network and go under the “Home” profile and have full access without controls. I will then move the device under the Parental Controlled profile. The next day, the computer will connect to the network, again, under the Home profile and have full access without parental controls. I will have to movie it under the other profile, and will be a duplicate device.
In the screenshot you can see the same device listed multiple times.
Net gear CM1000
tamason8
Screenshot
