claudiut
Dec 07, 2021Apprentice
Device Manager error CDIL-API-FAIL (RBR750)
I've recently updated to the latest firmware for my RBR750 system and since the Orbi app (iOS 15) has a few issues: 1. Every time I tap on Device Manager I'm getting an error "CDIL-API-FAIL" erro...
- Jul 06, 2022
This issue CDIL-API-FAIL (RBR750) on my router is fixed. I had a call with customer care(may be technical) for an hour long.
He helped me upgrade the firmwares of my Router and Satellites to RBR750-V4.6.8.5 and RBS750-V4.6.8.5.
After upgrading the firmwares and doing a factory reset the issue is resolved. Now I am able to access Device Manager and could Pause/Resume the devices.
Dec 08, 2021Guru - Experienced User
Can you see a listing of the RBR750 and a LOCALLY connected option?
What mobile devices are you using? Android or Apple?
- claudiutDec 08, 2021Apprentice
Yes, I see the locally connected option for RBR750; i selected it, but no change in behavior (same error)
Using Apple devices (iPhone and iPad) I installed the app on both ipad and iphone just to see if it makes any difference
FURRYe38 wrote:Can you see a listing of the RBR750 and a LOCALLY connected option?
