claudiut
Dec 07, 2021Apprentice
Device Manager error CDIL-API-FAIL (RBR750)
I've recently updated to the latest firmware for my RBR750 system and since the Orbi app (iOS 15) has a few issues: 1. Every time I tap on Device Manager I'm getting an error "CDIL-API-FAIL" erro...
- Jul 06, 2022
This issue CDIL-API-FAIL (RBR750) on my router is fixed. I had a call with customer care(may be technical) for an hour long.
He helped me upgrade the firmwares of my Router and Satellites to RBR750-V4.6.8.5 and RBS750-V4.6.8.5.
After upgrading the firmwares and doing a factory reset the issue is resolved. Now I am able to access Device Manager and could Pause/Resume the devices.
Guymconners
Dec 15, 2021Aspirant
I have, just this am, started getting the same issue. Firmware version 2.7.3.22. I do have internet access, and everything is working fine just do not have control from the iOS app. I can log into the router via my PC and see that everything is connected as usual. Error shows up as follows: device offline:: CDIL-API-FAIL
I would like to get a fix as I manage the devices via parental controls to limit the amount of time and what time the devices are allowed to be used.
No firmware updates are available.
- claudiutDec 15, 2021Apprentice
I hear you, I'm in the same boat.
Just out of curiosity: did you do any firmware updates recently to your system? The timing for me coincides with 4.6.5.14 firmware update for my Orbi RBK753 system
Guymconners wrote:I have, just this am, started getting the same issue. Firmware version 2.7.3.22. I do have internet access, and everything is working fine just do not have control from the iOS app. I can log into the router via my PC and see that everything is connected as usual. Error shows up as follows: device offline:: CDIL-API-FAIL
- GuymconnersDec 15, 2021Aspirant
Week or so ago, maybe longer. But I have used the app with no issue after that time.
Also I should note that I now am not having the issue after multiple reboots.
So not sure that is the fix as I have seen where others did this with no results
- claudiutDec 15, 2021ApprenticeMultiple reboots of the Orbi system?
I've done a few reboots of my Orbi already + re-installing the app on my iOS device; no changes for me, I'm still having this stupid error.
