claudiut
Dec 07, 2021Apprentice
Device Manager error CDIL-API-FAIL (RBR750)
I've recently updated to the latest firmware for my RBR750 system and since the Orbi app (iOS 15) has a few issues: 1. Every time I tap on Device Manager I'm getting an error "CDIL-API-FAIL" erro...
- Jul 06, 2022
This issue CDIL-API-FAIL (RBR750) on my router is fixed. I had a call with customer care(may be technical) for an hour long.
He helped me upgrade the firmwares of my Router and Satellites to RBR750-V4.6.8.5 and RBS750-V4.6.8.5.
After upgrading the firmwares and doing a factory reset the issue is resolved. Now I am able to access Device Manager and could Pause/Resume the devices.
KevinLiT
May 20, 2022NETGEAR Moderator
Hello madhu3110 ,
This issue occurs when the Orbi app thinks that your unit is offline. Please try rebooting your RBR750 then access the app. If you receive the error message again shake your phone and select report bug.
Please let me know if this resolved your issue!
Best,
Kevin
Community Team
UAnick
May 22, 2022Initiate
This started today after having to reset router. Online shows all of our 44 connected devices, app (iOS 15) shows 0 and this error message. Rebooted router, uninstalled app, reinstalled, reset router, etc, several times to no avail! Firmware current...so frustrating, when will you fix this?
- mshahnamMay 26, 2022Aspirant
I am having the same issue. Started several weeks ago and have done all that is suggested, reinstalled the app, firmware is updated. Running the app on IOS. I have noticed it takes several hours or maybe next day and all of a sudden all the devices show up but if I reboot everything is gone again and get this error. Also remotely I lose my ability to access when this issue happens. Any fix or update on the fix?
Thanks
