claudiut
Dec 07, 2021Apprentice
Device Manager error CDIL-API-FAIL (RBR750)
I've recently updated to the latest firmware for my RBR750 system and since the Orbi app (iOS 15) has a few issues: 1. Every time I tap on Device Manager I'm getting an error "CDIL-API-FAIL" erro...
- Jul 06, 2022
This issue CDIL-API-FAIL (RBR750) on my router is fixed. I had a call with customer care(may be technical) for an hour long.
He helped me upgrade the firmwares of my Router and Satellites to RBR750-V4.6.8.5 and RBS750-V4.6.8.5.
After upgrading the firmwares and doing a factory reset the issue is resolved. Now I am able to access Device Manager and could Pause/Resume the devices.
madhu3110
Jul 06, 2022Aspirant
Jul 08, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
