nshenorbi
Jul 12, 2022Aspirant
device set up with app
I'm about to set up another Orbi mesh wifi in another location. Do I have to use a unique account for existing vs new? I'd like to manage location 1 and location thru the app.
CrimpOn
Jul 12, 2022Guru - Experienced User
My understanding is that the app will allow you to administer more than one system.
Select the "hamburger menu" in the upper left part of the screen, then select "Set up New System".
nshenorbi
Jul 13, 2022Aspirant
Thanks - will give it a shot
- nshenorbiJul 15, 2022Aspirant
I was able to do the set up of the new system at a different location using the app but I can't seem to manage it, even though I am on the same local wifi. Keeps defaulting to my original setup system in the original first location. Is it possible to manage two systems?
- CrimpOnJul 15, 2022Guru - Experienced User
When you click on the "hamburger menu" (in the upper left) and then on the line that says "Connected" what happens?
I've left the second location, but if I recall, it was showing my 1st (original) system. Was not my 2nd location system. Did I miss a configuration?
