StevieDo
Apr 11, 2023Guide
Extended Warranty on my Orbi Mesh System
The Orbi Mesh SYSTEM I bought included a 750 Router and one satellite. This is the RBK752 SYSTEM. Netgear is very quick to sell things like ARMOR, Parental controls and Extended Warranties. I bought ...
- Apr 29, 2023
To update this issue, I received a call from Netgear today to apologize to me and make clear that both my router and satellite are covered by the extended warranty. Thanks to everyone who helped!
Apr 27, 2023Guru - Experienced User
StevieDo
Apr 27, 2023Guide
Thanks for helping. The comment I made earlier about it not being fixed was about the Network map in the Orbi App (which is now fixed by a software update BTW). Sorry for the confusion. My RBS has always worked fine. The issue is I bought an extended warranty on the mesh system I bought, which is a router and a satellite. Netgear's site indicates they are only going to cover the router (not the satellite) IF something does break. Calls to tech support have not helped as they state that is their policy. You said you passed it on to Netgear, but I have not seen them willing to honor the whole system with the warranty. If it never breaks, I guess I will not have a problem...if that satellite breaks and they leave me hanging, I will be furious. If you make reliable products, why pull this on your customers?
- KevinLiTApr 28, 2023NETGEAR Moderator
Hello StevieDo ,
Welcome to the NETGEAR Community!
NETGEAR ProSupport Extended Warranty extends the Limited Hardware Warranty for a supported and new NETGEAR product for which you purchase the Extended Warranty. You must purchase Extended Warranty within 90 (ninety) days from the date of Your purchase of a supported and new NETGEAR product. While a supported and new NETGEAR product is under warranty, NETGEAR will repair or replace Your product with the same or functionally equivalent product free of charge. Extended Warranty only covers a supported and new NETGEAR product for which you purchase
Extended Warranty.For more information in regards to NETGEAR ProSupport Extended Warranty please navigate to the links below:
NETGEAR ProSupport | NETGEAR Support
Best,
Kevin
Community Team
- StevieDoApr 29, 2023Guide
Thanks Kevin. What you posted actually supports my claim that I purchased an extended warranty on a new Netgear product (the RBK752) within 90 days and therefore my RBK752, which is a router and satellite, should have hardware coverage. Why is Netgear trying to say they are only going to cover the router and not the satellite? It seems they are just trying to anger customers for no good reason.
