Kfir-E
Apr 18, 2020Follower
Fail to speedtest- connection failed
I got the Orbi AX4200 RBK752, and I am trying to perform speedtest and it keeps givimg me " Failure to Connect" . At first the numbers where rinning and then i would get the error message and now...
Apr 20, 2020Guru - Experienced User
Which speed test are you doing? The internal one on the RBRs web page or from a different location or app?
Try Parental or Access Controls on the RBRs web page.
You'll have to keep an eye on the releases notes as FW updates come out. No idea if or when Circle or Armor will be included or not.
