Kfir-E
Apr 18, 2020Follower
Fail to speedtest- connection failed
I got the Orbi AX4200 RBK752, and I am trying to perform speedtest and it keeps givimg me " Failure to Connect" . At first the numbers where rinning and then i would get the error message and now...
gchin3
Sep 09, 2020Initiate
Similar problem. The Internet Speedtest from the Orbi app appears to have stopped working. "Connection Failed. If the problem persists, try rebooting your router." Ok...did that (multiple times)...still have error message. Rebooted my cable modem (Netgear CM1000)...still no joy.
Run speedtest from a Mac (connected to the router)...and speeds are normal. Ran "speedtest" on my phone (not using Orbi App)...and speeds are OK. Problem with app?
Suggestions?
Sep 09, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
gchin3 wrote:Similar problem. The Internet Speedtest from the Orbi app appears to have stopped working. "Connection Failed. If the problem persists, try rebooting your router." Ok...did that (multiple times)...still have error message. Rebooted my cable modem (Netgear CM1000)...still no joy.
Suggestions?
