beckss1
Oct 30, 2020Tutor
How to enable anywhere access
Dear gurus. Could you please explain why when enable anywhere access from application all time receive error "something go wrong ...." and if exist option to enable this from orbilogin dashbord mana...
CrimpOn
Oct 30, 2020Guru - Experienced User
beckss1 wrote:
Dear gurus.
Could you please explain why when enable anywhere access from application all time receive error "something go wrong ...." and if exist option to enable this from orbilogin dashbord managment.
Thanks and best regards,
Stas
The Everywhere Access function in the Orbi "app" is more likely to get an informed response if posted in the community forum that discusses the Orbi app: https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
I have seen the question posted here a couple of times and the only answer I recall is (a) keep trying and eventually it will work, or (b) reinstall the Orbi and app. (not much help.)
I do not find the Orbi app very helpful, so I use VPN access to reach my Orbi when not at home.
beckss1
Oct 30, 2020Tutor
Hi.,
Could you explain steps for building VPN or point to post where I can receive information for this.
Thanks and regards
