Daza1669
Sep 27, 2024Follower
How to get support for Orbi Mobile App, device trust and truble selecting Anywhere Access 2409271451
I am experiencing a couple of issues with Orbi app on iPhone but cannot find how to get support for them. Basically, after an app update -I guess, it asked me to login again. I did that eventually as...
KevinLiT
Sep 27, 2024NETGEAR Moderator
Hello Daza1669,
Welcome to the NETGEAR Community!
I understand that you are having issues with using Anywhere Access using the Orbi app since you are unable to register your iPhone as a trusted device. Please log into your Orbi app disable anywhere access logout. Now log back into your Orbi app then reenable Anywhere Access.
Best,
Kevin
Commuinty Team
