Retired_Member's avatar
Retired_Member
May 29, 2024
I can not see how many devices connect!
Hello
I can not see how many devices for connect in the app!
Please tell how to do see it for web ! Thanks
  • CrimpOn's avatar
    CrimpOn
    Enter the router model number into this web site (support.netgear.com ), select it, and then open the router User Manual.
    Search for "Attached Devices".
  • michaelkenward's avatar
    michaelkenward
    Which app? iOS or Android?
    Can you get the app to connect to your unknown Netgear device?
    Look at the Device Manager tile.
    What do you mean by "for web"?
    Tell us what you are trying to do and someone might be able to offer some clues.
