travisinfla
Jan 31, 2024Tutor
Installed 970 a few minor bugaboos
First of all these things are enormous, no putting them in a legrand media enclosure like the 6E - too wide. Will need to mount above it. I upgraded my switch to the unmanaged Netgear x508M with 8x1...
Feb 01, 2024Guru - Experienced User
FYI about RBR and RBS LED behaviors:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Network map meaning the Orbi network map?
Can you take a screen capture and post here for review?
What mobile platform are you using?
Version of Orbi app thats installed?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
travisinfla
Feb 01, 2024Tutor
See attached photo satellite 2 does not show up even though its connected and devices attached
