awawaw
Sep 19, 2020Guide
iOS 14
After upating my iphone to iOS 14, I cannot log into the Orbi application via local access. I can still access via remote access. Please help.
- Sep 29, 2020
Update 29 September 2020.
Orbi has released a new update 2.6.4.13 and my problem has been solved. It is working now. Thank you everybody.
GMoGoody8
Sep 20, 2020Luminary
IOS 14 has a new permission for local network. Please make sure you have given the Orbi app those permissions.
Also if you had any parental controls, MAC filtering or static IP addresses IOS 14 also now has MAC randomization per SSID. The first time the IOS 14 device joins an SSID it creates a unique MAC address. So all features using the real MAC will now fail.
Apple allows a user to toggle it per network if you want. Though it’s on by default. Hit the “I” and it’s the “private address” toggle
