awawaw
Sep 19, 2020Guide
iOS 14
After upating my iphone to iOS 14, I cannot log into the Orbi application via local access. I can still access via remote access. Please help.
- Sep 29, 2020
Update 29 September 2020.
Orbi has released a new update 2.6.4.13 and my problem has been solved. It is working now. Thank you everybody.
Sep 20, 2020Guru - Experienced User
iOS14 support. " Please ensure that you grant "Local Network" access so that the app can communicate with your Orbi WiFi system."
awawaw
Sep 20, 2020Guide
Yes yes. I did that from day one already.
Another update. I also downloaded the Orbi Appication to a work cell phone which is running Android and it is also no problem. I still think it has something to do with the Apple Watch. I hope either iOS has an update that will help or Orbi has an update. It is often that both sides point towards the other guy.
- MstrbigSep 20, 2020Master
awawaw wrote:Yes yes. I did that from day one already.
Not to knock Apple, but I see a lot of complaints with regard to Orbi and Apple products such as iPhone, iPad, Mac Pro, Macbook air, etc.
- Dfran1Sep 20, 2020Apprentice
Mstrbig wrote:
Not to knock Apple, but I see a lot of complaints with regard to Orbi and Apple products such as iPhone, iPad, Mac Pro, Macbook air, etc.I have updated all my apple devices to latest ios , iwatch, apple tv's (3), 2 Iphones, ipad, macbook pro and mac mini (no new osx release yet for macbook and mac mini), besides all the other wifi stuff i have and no issues at all, yes I clicked on the local network and you can find it also in the app name under settings, in case someone needs to know.
I also must say I firmware locked my orbi and Orbi (RBK50-100NAR) has been the best router I have ever owned.
(Not to say bad things about firmware updates, but I had just Horrible times with Orbi firmware updates, spent wayyyyyy too much time trying to fix them and nothing would in my case.) so I put that orbi at work as no satelite needed their and I do update the main orbi all the time at work only and that has been perfect. I have 3 other Orbi's with satelite's (all firmware locked at what they all came shipped with) now at 3 houses (only one is mine) and no problems.
I did also turn on jumbo frames by this method (certainly not sure this helps)
Launch your favorite web browser and go to <Router IP Address>/debug.htm
Best of luck to all!!
- Christian_RSep 25, 2020NETGEAR Employee Retired
Hi awawaw & Dfran1,
If you're still experiencing issues with accessing the Orbi app, please send me the following info in a private message.
Orbi Router Model:
Orbi Firmware Version:
Orbi App Version: (iOS or Android)
Did you update to iOS 14: (Yes or No)
Thanks,
Christian
