awawaw
Sep 19, 2020Guide
iOS 14
After upating my iphone to iOS 14, I cannot log into the Orbi application via local access. I can still access via remote access. Please help.
- Sep 29, 2020
Update 29 September 2020.
Orbi has released a new update 2.6.4.13 and my problem has been solved. It is working now. Thank you everybody.
awawaw
Sep 20, 2020Guide
Yes yes. I did that from day one already.
Another update. I also downloaded the Orbi Appication to a work cell phone which is running Android and it is also no problem. I still think it has something to do with the Apple Watch. I hope either iOS has an update that will help or Orbi has an update. It is often that both sides point towards the other guy.
Mstrbig
Sep 20, 2020Master
awawaw wrote:Yes yes. I did that from day one already.
Not to knock Apple, but I see a lot of complaints with regard to Orbi and Apple products such as iPhone, iPad, Mac Pro, Macbook air, etc.
- Dfran1Sep 20, 2020Apprentice
Mstrbig wrote:
Not to knock Apple, but I see a lot of complaints with regard to Orbi and Apple products such as iPhone, iPad, Mac Pro, Macbook air, etc.I have updated all my apple devices to latest ios , iwatch, apple tv's (3), 2 Iphones, ipad, macbook pro and mac mini (no new osx release yet for macbook and mac mini), besides all the other wifi stuff i have and no issues at all, yes I clicked on the local network and you can find it also in the app name under settings, in case someone needs to know.
I also must say I firmware locked my orbi and Orbi (RBK50-100NAR) has been the best router I have ever owned.
(Not to say bad things about firmware updates, but I had just Horrible times with Orbi firmware updates, spent wayyyyyy too much time trying to fix them and nothing would in my case.) so I put that orbi at work as no satelite needed their and I do update the main orbi all the time at work only and that has been perfect. I have 3 other Orbi's with satelite's (all firmware locked at what they all came shipped with) now at 3 houses (only one is mine) and no problems.
I did also turn on jumbo frames by this method (certainly not sure this helps)
Launch your favorite web browser and go to <Router IP Address>/debug.htm
Best of luck to all!!
- Christian_RSep 25, 2020NETGEAR Employee Retired
Hi awawaw & Dfran1,
If you're still experiencing issues with accessing the Orbi app, please send me the following info in a private message.
Orbi Router Model:
Orbi Firmware Version:
Orbi App Version: (iOS or Android)
Did you update to iOS 14: (Yes or No)
Thanks,
Christian
- awawawSep 29, 2020Guide
