wongmich
Dec 01, 2020Aspirant
IOS app not showing updated RBS20 info and constant magenta after resync
I had to reboot my RBR20 after a power loss for the router only. Since the 2 satellites now show magenta dot per the IOS app's network map, I resync them. After resync the two existing satellites (R...
Christian_R
Dec 08, 2020NETGEAR Employee Retired
Hi wongmich,
Have you had a moment to reinstall the Orbi app?
Christian
- wongmichDec 08, 2020Aspirant
Reinstalling the IOS app makes no diff. However when I update the firmware to 36 and 38 respectively from 16, it kind of wakes up the app and it now correctly reads the new parameter for both the base and satellites.
I was one step away from factory reset everything and glad I did not have to do that.
