CarisaW
Aug 24, 2020Aspirant
IOS APP Speed test does not work & phone is now showing as satellite.
Any suggestions on how to fix the speed test in the iOS app? I get a Connection Failed message whenever I try to run. I tried resetting Orbi to factory setting, rebooting many times, deleting and rei...
Fritzsche0529
Sep 12, 2020Apprentice
I am having the same problem with the speed test on the iOS app. It worked when I first installed the Orbi (RBR750), but after about a week stopped working (about a week ago) I got the same connection error you report. I have been through all of the same steps to try to correct it, including contact with NETGEAR. No luck yet.
- Christian_RSep 18, 2020NETGEAR Employee Retired
Hi Fritzsche0529,
Has support been able to get in touch with you regarding your issue?
Christian
- CarisaWSep 18, 2020AspirantNo contact from support on this issue.
- BiGMERFSep 19, 2020Apprentice
alot of people are having the same issue. including myself... your not alone...
- Fritzsche0529Sep 19, 2020Apprentice
I have had contact with Netgear and was unable to resolve the problem. They have escalated the problem (to experts?) but I have not had the time to contact them (they reached out, so this is not on them). It is hard to find a time when I can take down WiFi to work through possible solutions. The WiFi itself is fantastic...I just want the SpeedTest to work. I'll follow up with a post if I can get this fixed.
- BiGMERFSep 19, 2020ApprenticeYea they told me the same thing. Escalated it. Is it true ? Idk
