CarisaW
Aug 24, 2020Aspirant
IOS APP Speed test does not work & phone is now showing as satellite.
Any suggestions on how to fix the speed test in the iOS app? I get a Connection Failed message whenever I try to run. I tried resetting Orbi to factory setting, rebooting many times, deleting and rei...
tuxbox78
Sep 21, 2020Aspirant
Hi, same here as of the latest app update for ios 14 the speedtest
won't work anymore. Always tells internet would not be working,
but it is and also webfrontend tells internet: good.
Having RBR850 with very latest firmware running.
BiGMERF
Sep 21, 2020Apprentice
since I was in my initial 30 days and my system was acting foolish.. I swapped it for another.
With my past system the speed test had all of a sudden gone out. It had happened before the iOS 14 update.
with this new system it is working on both my iPad and iPhone running iOS 14, so it can't be that.
if it all of a sudden goes on this system after working a few days... then it has to be something triggered
- Fritzsche0529Sep 21, 2020ApprenticeYes, I agree that the iOS 14 is not the problem because the problem existed prior to the iOS release. I was actually hoping it would fix the problem but it didn’t. I have a feeling you’re right about the delay issue. Mine worked for over a week then stopped. Hopefully you have better luck with your new system.
- CarisaWSep 21, 2020AspirantI too thought iOS update would have fixed. I thought it might have been related to Armor as the security trial was added a few days after I set up my system. It was after I started the trail that the speed test stopped working. That is when I reset to factory default and attempted to start from scratch. It was after iOS update that my phone and now my Mac is showing as a satellite.
