CarisaW
Aug 24, 2020Aspirant
IOS APP Speed test does not work & phone is now showing as satellite.
Any suggestions on how to fix the speed test in the iOS app? I get a Connection Failed message whenever I try to run. I tried resetting Orbi to factory setting, rebooting many times, deleting and rei...
Fritzsche0529
Sep 24, 2020Apprentice
I was finally able to speak to a Netgear support rep, Rose. The delay was from my end, not theirs. She performed a factory reset remotely on my router, and I went through the steps to set up a new router. The reset was initiated from within the router web page (I don’t know exactly where on the page the reset was accessible since I was not doing it, but to be clear, it was not via the app). I had reset and unplugged the router multiple times before, but I may not have performed a “factory reset”. After the router had restarted and I finished the installation process, the SpeedTest via the app worked. Considering that the app worked for me previously and then stopped, much like what has happened to most of you who have posted here, I’m cautiously optimistic that this is a permanent fix. But I have to say that Rose was great and I’m back in business...at least for now.
BiGMERF
Sep 25, 2020Apprentice
I've had my new system since the 21st after returning the previous one due to a few issues including the Speed test. So far so good, buts only been four days. Last time it went out at day 5
