yamoinca
Feb 17, 2021Aspirant
IOS Orbi app “wifi not detected”
With RBR 40. Note router and everything else is working fine. Even Orbi app on different iPhone same iOS version works. I have seen the other posts and it is not local network setting being disabl...
Christian_R
Feb 19, 2021NETGEAR Employee Retired
Hi yamoinca,
May you provide the current Orbi app version you have installed n your iPhone XS Max.
Christian
- lgarretMar 02, 2021Aspirant
christian, what is the solution here, i am facing the same problem, cant get the app to connect to wifi???
please help, cant turn on the kids internet for school work........
app version 2.8.5.15, fresh download from app store on ios
- Christian_RMar 03, 2021NETGEAR Employee Retired
Hello lgarret,
May you provide the model number of your router and check to see if your router is due for a firmware update.
Christian
