Networksniffer
Sep 24, 2020Guide
iPhone IOS 14.01 problems with Orbi App
Hi, I am having trouble with the new IOS 14 system in combination with the Orbi App. After reading that there must be granted access to the local network in the privacy tab off iOS 14. I thought "le...
- Oct 01, 2020Hi,
Everything works now after the new release.
Thanks.
Christian_R
Sep 25, 2020NETGEAR Employee Retired
Hello Networksniffer,
May you refer to the article below and see if you're able to view the local network access slider in your iPhone's settings. You may need to reinstall the Orbi app.
Christian
Networksniffer
Sep 25, 2020Guide
hello Christian,
that's the problem. In the local Network list normally is the app Orbi but after the reinstall the app Is gone. I have reinstalled it 4 times it doesn't come back. So if there is a way to get the Orbi app back in the list it will probably work.
greetings
pascal
