Networksniffer
Sep 24, 2020Guide
iPhone IOS 14.01 problems with Orbi App
Hi, I am having trouble with the new IOS 14 system in combination with the Orbi App. After reading that there must be granted access to the local network in the privacy tab off iOS 14. I thought "le...
- Oct 01, 2020Hi,
Everything works now after the new release.
Thanks.
Christian_R
Sep 25, 2020NETGEAR Employee Retired
Hello Networksniffer,
May you refer to the article below and see if you're able to view the local network access slider in your iPhone's settings. You may need to reinstall the Orbi app.
Christian
Speast
Sep 26, 2020Tutor
Where is the local access slider on the iPhone? I've googled it and found no answer.
The verification method to send to iPhone thru a push notification and the email option locks up (ie the "Continue" button is greyed out).
Thanks!
