Networksniffer
Sep 24, 2020Guide
iPhone IOS 14.01 problems with Orbi App
Hi, I am having trouble with the new IOS 14 system in combination with the Orbi App. After reading that there must be granted access to the local network in the privacy tab off iOS 14. I thought "le...
- Oct 01, 2020Hi,
Everything works now after the new release.
Thanks.
Speast
Sep 26, 2020Tutor
Where is the local access slider on the iPhone? I've googled it and found no answer.
The verification method to send to iPhone thru a push notification and the email option locks up (ie the "Continue" button is greyed out).
Thanks!
Networksniffer
Sep 26, 2020Guide
Hi
I think there is no local access slider. When you install the Orbi app it creates a record called Orbi in privacy /local network. This has a slider which give your Orbi app access to the local network. This must be green. When you slide it left it is off and colored gray. That is what they probably mean.
