Networksniffer
Sep 25, 2020Guide
iPhone IOS 14.01 problems with Orbi App
Hi, I am having trouble with the new IOS 14 system in combination with the Orbi App. After reading that there must be granted access to the local network in the privacy tab off iOS 14. I thought "le...
- Oct 02, 2020Hi,
Everything works now after the new release.
Thanks.
Speast
Oct 09, 2020Tutor
This is exactly my issue. Is there anyone from Netgear that would like to respond to this so it can be resolved? And ideally please respond at a level that is easy for everyone, not just techies, to understand. Thank you.
afff50v2
Oct 09, 2020Guide
I found another thread from someone who called Netfear, stayed on the line for 90 minutes and actually spoke to someone at netgear. he said it is a known problem with the app and that they are 'working on it'. they told him of the work around where you select 'don't trust this device' and proceed as usual. then it will open the app and you can update the firmware and work with the app like you used to be able to do. I tried it and it worked for me! After trying everything else - this is what it took. Not selecting my iphone as a 'trusted device'. smh. I hope it works for you.
- GY84Oct 13, 2020Tutor
Just uninstall/reinstalled yet again to try this "don't trust device" method.... it didn't work. Exact same result as last time. Most frustrating part is I just downloaded the new orbi app update 5 min ago, and it's still broken! Idk how they mark this thread as issue solved
- NetworksnifferOct 13, 2020GuideHi.
Here the same. The iPhone ask for a thrust device and the it’s done. The orbi app quits en can’t login. Trying to deactivate the verification option but this also changes nothing. So still waiting on a solution
Greetings all
