Yahey
Dec 21, 2021Aspirant
Issue to have ORBI app detecting my installed ORBI network
Hello Community, ** As requested, I'm opening a dedicated thread for my issue ** I have an issue to have ORBI app detecting my installed ORBI network. My ORBI network is working just fine...
Yahey
Jan 06, 2022Aspirant
Hi all,
I started everything from scratch again.
Router + satelitte reset.
Reinstallation using ORBI app.
Works fine on initial setup.
Until I change the LAN IP range (replacing the default one by a new one).
Since then, ORBI app is not working anymore, saying that ORBI network cannot be found.
I saw some post on PlayStore saying that since last app update, other people have the same issue.
Therefore I definitely do believe that the issue comes from the app itself.
Waiting for new app update to resolve the issue ...
Jan 06, 2022Guru - Experienced User
If changing the IP range is whats associated with it having issues, then why not leave it the default ip range?
What modem/gateway is the router connected to?
- YaheyJan 13, 2022Aspirant
Hi,
:) Of course I could keep the default one (as a workaround) but this is not what I want at the end.
And it worked for months without the default IP range.
The ORBI router is connected to the ISP (Orange fiber 1 GB) box. Configured in the DMZ.
