berderking
May 07, 2024Guide
LBR20 Anywhere Access “device already registered”
Hi, Looking for help from netgear support. I’m trying to use anywhere access on my LBR20 and it says “this device is already registered” with an email that’s not mine. Thanks
berderking
May 10, 2024Guide
michaelkenward 2nd hand and netgear says they can't help since I don't have the original receipt.
Any ideas?
CrimpOn
May 10, 2024Guru - Experienced User
A truly awkward situation. When the original owner who registered the product with Netgear got rid of it, they obviously neglected to "unregister" it. If there was some way to contact the original owner, they could fix the whole thing in a few minutes. Netgear, of course, is not going to provide the email address so that you can contact the person yourself.
Bummer.
I would think that the Orbi 'app' would not function with the router in any way.(not just Anywhere Access)
If the goal is to administer the Orbi system when not able to connect locally to the web interface, an alternative is to enable OpenVPN on the router. See page 111 in the LBR20 User Manual:
https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_UM_EN.pdf
- berderkingMay 10, 2024Guide
CrimpOn Actually everything does work in Orbi app except anywhere access....
- CrimpOnMay 10, 2024Guru - Experienced User
Thanks for the explanation. "new to me" as I had thought that the connection between Orbi 'app' and router was tied to the Netgear.com login used. (i.e. if one Netgear login registered the product, then another Netgear login could not use the app with the router.) This forum teaches me new things every day.
One of the things that catches some people is that the Orbi 'app'
- Can be installed on any number of user devices at the same time, and each can have different settings.
- Can enable Anywhere Access only when the user device is connected locally to the Orbi WiFi system.
- Some user devices can have Anywhere Access enabled and other devices not enabled.
- berderkingMay 12, 2024Guide
CrimpOn it’s actually my case, I have another couple of devices I have anywhere access on that I monitor through the orbi app.
I can connect to the LBR20 locally with no problem as well.
