TraxTrin
Jun 06, 2023Aspirant
Lost Security and parental controls
I know there are a few posts about this. But nothing seems to help me. I had the orbi app installed on two phones and all worked nice. I have subscribed to armour security now and suddenly one app...
CrimpOn
Jun 06, 2023Guru - Experienced User
TraxTrin wrote:
I have uninstalled and reinstalled the app but it doesn’t come back on on iPhone.
Does iPhone have options to "Clear Cache" and "Clear Data" similar to Android phones? (I am not confident that removing the app will clear everything from the phone.) My practice is to clear both, then remove the app. (but then I do a lot of things that make no sense.)
You can at least "shake that thing" and report a bug. May release a tiny bit of tension.
- TraxTrinJun 06, 2023AspirantI got it to work.
I had to change my email to a different one and back to the old one.
I know. It sounds strange. But I tried everything.- FURRYe38Jun 06, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- TraxTrinJun 27, 2023Aspirant
Same problem again. Orbi app got deleted, re-installed and Armor brings up error message and no parental controlls
