Hauw
Jun 30, 2020Aspirant
Magenta status on RBR10
Hi, Recently I bought RBK13 Multiroom Wifi 3-pack for our home. It works fine after installation. But I still have a question about the color of the dot on the Orbi app. The router RBR10 is conne...
- Jul 01, 2020
Ok
I beleive this is a Orbi app issue. I'll direct you to the orbi app forum from here.
Good Luck.
Hauw
Jul 01, 2020Aspirant
Just want to give you feedback:
I've configured the Orbi router to AP mode and leave the wifi radios on the router activated. The internet connection via wifi of the Orbi router and of the modem is working perfectly. And on the Orbi app, the router and the satelites get a green dot now! Even the internet radio is also working.
Thank you very much for your quick support.
Jul 01, 2020Guru - Experienced User
Ok
Good Luck.
