CrimpOn
Mar 23, 2021Guru - Experienced User
Make Parental Controls GO AWAY
I have never activated any form of Parental Controls on my Orbi. I also seldom use the Orbi "app". When researching a question about the Orbi satellite "Connected Devices" display being incorrect, ...
CrimpOn
Thanks for the response. I am indeed on 2.7.2.104. However, I declined to activate Parental Controls and thus my home page does not include that item. (see attached).
I have this suspicion that Android app v2.8.6.1417 is the problem. It has no was to "just say no". (pun)
Ya, you would think PC would not be seen on the app of the routers FW isn't enabled for it.
