koltyn
Jul 18, 2023Follower
Manual Set Up Without Smartphone
Need help with the manual set up of orbi without downloading the app. 192.168.1.1 use to work but now comes up with a orbi page to login with username & password. Then when I log in, there is no opti...
Jul 19, 2023Guru - Experienced User
the time it takes you to the "setup without a smart phone" is when you're first setting it up.
If you've already set it up, you won't see that option. You can still log in through the browser to manage it.
