Anzenchitai
Jul 30, 2022Aspirant
Missing features from Orbi App
I m using RBKE963 with Firmware Version 6.0.3.88 and the Orbi App Version 2.18.1.3. However, I don’t see the Analytic features of channel selection and signal strength in there. Do I have to pay a su...
Aug 01, 2022Guru - Experienced User
Analytical Features are only available on pad mobile devices in some cases. Not supported on mobile phones.
There are free Analytical apps for Apple and Android.
What is 1500? Is this the size if your home?
CrimpOn
WiFi Analytics appears on the Android app on my mobile phone.
- FURRYe38Aug 01, 2022Guru - Experienced User
Maybe for the 50 series...I presume it depends on Orbi series and phone as well.
Analytics isn't seen on my iPhone though it's one my Android pad.
- AnzenchitaiAug 02, 2022Aspirant
Let me guess, NG is using WiFi Analyzer instead of developing a full app. This is why Apple devices don’t get the features of signal strength and suggestion of channel selection. On the iPad my choices are WiPry and WiFi Advisor which both of them require a purchase of detector.
- CrimpOnAug 02, 2022Guru - Experienced User
That could very well be the case. Netgear certainly did not write their own speed measurement software, instead using Speedtest by Ookla. Android does not have the same restrictions on accessing underlying technology as Apple. There must be more than a dozen "WiFi Analyzer" programs for Android.
