Retired_Member
Aug 15, 2019Move device to guest network
Is it possible to manually move a device from my primrary wi-fi network onto the guest network? I know I could remove the device from my primary and have the user connect to the guest network, bu...
- Aug 15, 2019
Retired_Member wrote:Is it possible to manually move a device from my primrary wi-fi network onto the guest network?
No.
Retired_Member wrote:I know I could remove the device from my primary and have the user connect to the guest network, but I'd love to be able to do this myself as the admin.
The problem is that you can't change the wireless client configuration of this device - thus it has to be done direct on the device.
schumaku
Aug 15, 2019Guru - Experienced User
No.
