1981JM
Dec 06, 2023Aspirant
my products
Hello, I have iphone 13 running under ios 17.1.2 and i have an update app of Orbi! But i 2 products when i go on the app! first i have orbi system on local connexion which is green second i have...
Dec 06, 2023Guru - Experienced User
Not a problem. That's how it works. You have a local access connection with Orbi app to the system and then you'll see a Anywhere Access connection for when your home or away at a remote location, which you can access the system remotely.
- CrimpOnDec 06, 2023Guru - Experienced User
I agree that the Orbi app functions when showing both the local connection and Anywhere Access on the app. What I have never understood is the reasoning behind choosing to use the Anywhere Access connection when the device running the Orbi app is connected locally.
What can be gained by sending every data packet through the Netgear Cloud rather than keeping the connection on the LAN? This cannot be faster. Consumer user internet data for no purpose.
My sense is that (just a guess), Netgear programmed the Orbi app to connect first through Anywhere Access and then look to see if the router can be found on the LAN. Notice the wording "Local connection available."
- michaelkenwardDec 07, 2023Guru - Experienced User
Even that doesn't always work for me.
Puzzlingly, when I am "Connected Locally" I lose the option to "Connect via Anywhere Access".
What I have never understood is the reasoning behind choosing to use the Anywhere Access connection when the device running the Orbi app is connected locally.Not just me then.
- CrimpOnDec 07, 2023Guru - Experienced User
michaelkenward wrote:
Puzzlingly, when I am "Connected Locally" I lose the option to "Connect via Anywhere Access".The Android and iPhone versions of Orbi app are (obviously) different because of the different platforms. I have Android. Perhaps our apps simply "work differently".
