May 04, 2022Guru - Experienced User
NETGEAR Mobile Applications and Android/Apple Devices FAQ
Symptoms:
Since Apples introduction of WiFi Private IP address and Limit IP tracking and iCloud Private Relay in there iOS, this seems to have been causing problems for users of Netgear's mobile applications, i.e. Nighthawk and Orbi applications on iPhones and iPads being able to connect correctly to Netgear router products. These are Apple features, not NETGEAR features.
What is:
WiFi Private IP Address:
"Apple platforms use a randomized media access control address (MAC address) when performing Wi-Fi scans when not associated with a Wi-Fi network. These scans can be performed to find and connect to a known Wi-Fi network or to assist Location Services for apps that use geofences, such as location-based reminders or fixing a location in Apple Maps."
https://support.apple.com/guide/security/wi-fi-privacy-secb9cb3140c/web
Limit IP Address Tracking:
"Limit IP address tracking is a privacy-enhancing feature currently only seen on iPhones or iPadOS devices with cellular connectivity. This feature can be activated on your device if you are running iOS 15.2 RC 2 or higher. Once enabled, your IP address will be hidden from identifiable trackers in Apple’s database. This feature will only work in Safari & Mail, for now, using another browser or Mail app will leave you exposed to trackers.
https://nerdschalk.com/hide-ip-address-on-iphone-how-to-use-limit-ip-address-tracking-feature-for-this/
https://discussions.apple.com/thread/253657312?answerId=256849570022#256849570022
iCloud Private Relay:
"When Private Relay is enabled, your requests are sent through two separate, secure internet relays. Your IP address is visible to your network provider and to the first relay, which is operated by Apple. Your DNS records are encrypted, so neither party can see the address of the website you’re trying to visit. The second relay, which is operated by a third-party content provider, generates a temporary IP address, decrypts the name of the website you requested and connects you to the site."
https://support.apple.com/en-gb/HT212614
Diagnosis:
When users are at home that these features may not be needed as there would be no reason to have additional security features on the iOS devices enabled while being at home and that these features are more suited for out of home or remote use while away from home and the local home network.
Solution:
For troubleshooting these problems with Netgear mobile applications, Apples WiFi Private IP address and Limit IP tracking on Apple iPhones and iPads can be disabled while at home to see if this helps resolve Netgear's mobile app in connecting to the Netgear router.
Try turning OFF WiFi Private IP address and Limit IP tracking features are found on the same screen page:
https://support.apple.com/en-us/HT211227
iCloud Relay can be turned off as a troubleshooting step as well though may not be needed in most cases:
https://support.apple.com/en-us/HT212614
NOTE: For help and infomration or troubleshooting regarding these Apple features, users will need to make contact with Apple support and get there help regarding there products and features.
Also seen on Android OSs as well:
https://www.howtogeek.com/722653/how-to-disable-random-wi-fi-mac-address-on-android/
NOTE: These are troubleshooting steps only and recommended trying if all other troubleshooting steps fail. Remember to enable these Android/Apple features when using Android/Apple devices normally or remotely outside of the home network.
If users still see problems with the mobile app after trying the solution, please submit a bug using the submit bug feature in the app:
Or contact Netgear support:
1 Reply
Updating this to reflect changes in Apple iOS behavior seen in iOS v18 and beyond.
Apple has implemented additional options to the Private WiFi Address feature.
3 options are now seen here:
1. Disable - Disables the MAC address randomization on the phone. Uses actual MAC address set on the phone.
2. Fixed - Sets a fixed MAC address that differs from actual MAC address of the phone.
3. Rotating - Randomized the MAC address. Good for traveling or connecting to open WiFi networks when away from home.
Enjoy.
