radderthanrad
Mar 29, 2019Aspirant
Netgear Orbi app speed test inaccurate vs speedtest.net for AC2200 router, helped by CM600 modem
I just set up my new CM600 modem a few nights ago because my Orbi 2200 router was being unreliable. I bought the Orbi router has really helped cover my duplex apartment with good, reliable WiFi. I ha...
- Mar 29, 2019
The built in app with the orbi is hardwired into the orbi. So its going off a hardwired speed. I notice your screen shot is from a wireless device. The wireless device might be connected to teh 2.4ghz or if its on 5ghz might be having interference in your area. Try hardwiring in your laptop and testing the speeds that way. That'll give you an accurate measure of your speeds. Your results of that dictate the best way to troubleshoot this to be a connectio problem to a wireless issue.
Mar 29, 2019Guru - Experienced User
radderthanrad
Apr 05, 2019Aspirant
Thank you.
That makes sense. I was hoping the Orbi app's speed test functionality would allow me to determine the best location for satellite routers by testing the speed from my wireless devices, but if it only tests the speed of the main router connected to my modem, then that doesn't seem to be the case and I would need to use a third-party solution. Thank you.
- plemansApr 05, 2019Guru - Experienced User
Speedtest is the app that the built in Orbi uses. You can use the same app on your phone for testing placment. Keeping in mind, you should run the test several times because Orbi will dynamically change 2.4-5ghz as needed for speed.
