johnny_rumely
Jul 12, 2022Aspirant
Netgear RBKE963
Hi everyone, I’m having issues with setting up my Orbi via Ethernet backhaul, 1st issue, I setup my satellite via Ethernet backhaul, it shows that it’s connected on the Orbi login website but it do...
Jul 12, 2022Guru - Experienced User
Where a screen capture of this on the Orbi app?
There is current problems with Orbi app.
What is the brand and model # of the switch being used? Is the switch supporting of 2.5Gb connections?
What CAT# lan cable is being used? CAT6 is recommended for 1Gb port connection. CAT6A STP is recommended for 2.5Gb port connections.
