Deepak_Mehta
Feb 26, 2021Aspirant
Network Map Issue
Hi, I have 1 Main Orbi Router RBS 850 and 6 Satellite but in the map eveytime it show only 3 satellites? Can someone help me to how can i see all the orbi satellite in the Network map?
- Mar 03, 2021
Hi Deepak_Mehta
Chuck_M is right. The Orbi App Network map / topology view is limited to a maximum of 3 satellites. This is a design limitation. For you to check the list of Satellites, you may need to tap on "Tap here to see additional satellites"
Blanca
Community Team
Deepak_Mehta
Mar 01, 2021Aspirant
Are you using the Orbi app? (YES)
Are the RBS seen on the RBRs web page using a web browser? ( YES)
What Firmware version is currently loaded? ( I GUESS THE LATEST ONE)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (STATIC IP )
Is the Orbi system operating in Router or AP mode? ( ROUTER MODE)
What is the size of your home? Sq Ft? (3 FLOOR 2500 SQ FEET)
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. (MORE THAN 30 FEETS SOME RBS ARE CONNECTED WITH WIRED CONNECTIONS)
Mar 01, 2021Guru - Experienced User
Deepak_Mehta wrote:Are you using the Orbi app? (YES)
What Firmware version is currently loaded? ( I GUESS THE LATEST ONE) There a number here?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (STATIC IP ) Is there a brand name and model number here?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. (MORE THAN 30 FEETS SOME RBS ARE CONNECTED WITH WIRED CONNECTIONS)Are the RBS connected directly to the RBR or is there a network LAN Switch in between the RBR and RBS?
- Deepak_MehtaMar 01, 2021Aspirant
RBR is connected to cisco unmanged switch, from there ethernet connections are attached to RBS
