Deepak_Mehta's avatar
Deepak_Mehta
Network Map Issue
Hi, I have 1 Main Orbi Router RBS 850 and 6 Satellite but in the map eveytime it show only 3 satellites?   Can someone help me to how can i see all the orbi satellite in the Network map?
  • Blanca_O's avatar
    Blanca_O
    Mar 03, 2021
    Hi Deepak_Mehta
    Chuck_M is right. The Orbi App Network map / topology view is limited to a maximum of 3 satellites. This is a design limitation. For you to check the list of Satellites, you may need to tap on "Tap here to see additional satellites"
    Blanca
    Community Team
